Setting up a workspace
Workspaces help you organize the application layout and adapt it to your customers’ needs. A workspace is a customizable container that includes different widgets represented as tables, charts, metrics and information chips. A customer can use several workspaces with different layouts and features depending on the user role.
To set up a workspace for your customers, follow these steps:
- Create a workspace: Create a workspace from a preset.
- Edit the application layout using the editor mode: Design a customized application layout tailored to your customers’ needs.
- Edit access to a workspace: Allow the newly created workspace for the user.
Creating a workspace
To create a new workspace that will define the application layout for your customers, follow the next steps:
Log in as a customer to Wialon Platform FleetSpace.
When you use the Log in as button to access a customer account, you have all the permissions and features available to you as a service provider. Customers logging in with their own credentials only see the functionality allowed and configured for them by the service provider.
Click the icon
in the sidebar to enable the editor mode. For more information on the editor mode, see the page Using editor mode. -
In the editor mode toolbar that appears at the bottom of the screen, click on the workspace name.
Select New workspace.
In the Current workspace field, select an existing workspace to use as a template.
Enter a unique and descriptive name for your new workspace.
Click Save.
The new workspace is now created and available for your service provider account. The next step is to allow it for the appropriate user.
Editing the workspace
To edit a workspace, click on your workspace name in the editor mode toolbar. The following actions are available:
- Change the workspace name
- Duplicate the workspace
- Delete the workspace
- Create a new workspace
You can’t delete a workspace while it’s granted to at least one user. First, remove it from the user permissions or from the roles assigned to the users.
Editing the app layout
The editor mode allows you to add, delete, and arrange features, modules, and menu items for the selected workspace.
To start editing the elements of the customer workspace, follow these steps:
In Wialon Platform FleetSpace, select the page you want to edit.
Click the icon
in the sidebar to select the workspace you want to edit. In the menu that opens you can see the current workspace. To change it, click on the Workspaces line and select the necessary workspace from the list.
If you have more than 7 workspaces available, use the search by workspace name.
You can’t edit the
defaultworkspace. -
Click the icon
Now you can start editing pages in the selected workspace.
Editing a page
Hover over the elements of the page to see the highlighted parts that you can change:
Show data on the tab by adding a new widget
Hide unnecessary data by deleting a widget
Change the order of the displayed information
Adjust the size of a widget on the Dashboard
The edited menu in the selected workspace will be visible to all the users who have access to that workspace.
Editing the sidebar menu
You can change the order of menu items, their names and icons in the left sidebar for your customers:
- Add a new page to the sidebar
- Edit the page: change the page name, icon
- Delete the page
- Change the order of pages in the sidebar
After adding all the necessary widgets, you can preview the changes in the workspace. To do this, switch to Preview mode using the button
in the editor mode toolbar and select a user from the user preview dropdown to simulate their session.
See the full guides for customizing workspaces on the following pages:
- Customizing the sidebar menu
- Setting up widgets on the Dashboard
- Setting up widgets in the device list
- Setting up widgets in the device details
Editing access to a workspace
Once a workspace is created, you must grant access to users. This ensures that when customers log in, they only see the workspaces available to them.
To modify access settings:
- Log in to Wialon Platform Studio.
- Go to the Customers page.
- Select the customer account that contains the user profile.
- Navigate to the Users tab.
- Select the user who should have access to the workspace.
- In the user profile, open the Permissions tab.
- Go to the Workspaces section.
- Check the box for the workspace you created. You can use the search above the list to find your workspace.
- Click Save.
Now, when the user logs in to Wialon Platform FleetSpace with their own credentials, they will be able to see the assigned workspace.
