Setting up the “Tachograph control” module
The Tachograph control module must be set up by the service provider in Wialon Platform Studio. Setting up the module includes:
- Installing the Tacho Bridge application
- Adding the application to the module
- Adding companies to the module
- Linking devices to the companies
Each of these steps is described below.
These steps are needed only to download tachograph files. Live tachograph data comes directly from the tracker, so it’s available without the Tacho bridge application and without a company card. For details, see Two sources of tachograph data.
Installing the “Tacho bridge” application
To install the Tacho Bridge application:
- In Wialon Platform Studio, expand the Connectivity section in the navigation menu and open the Tachograph control page.
- Follow the Tacho Bridge application link.
- Download the application. For Windows, use the download link with the .msi extension. For macOS, use the link with the .dmg extension.
- Install the Tacho bridge application on your computer.
Adding the Tacho Bridge application to the module
To add the installed application to the module:
- On the Tachograph control page of Wialon Platform Studio, copy the server address next to the application download link.
- Start the Tacho bridge application.
- Open the application settings (the icon
on Windows, or the Config button on macOS).
- In the App ident field, specify the application identifier. You can enter any value of 13 characters, but make sure it is unique within your account.
- In the Server address field, paste the copied server address.
- Click Save.
- On the Tachograph control page of Wialon Platform Studio, click Add application.
- Enter the name which you want to use for the Tacho bridge application installed on your computer.
- Specify the application identifier. It must be the same as in step 4.
- Click Save.
After that, the added application is displayed on the Tachograph control page.
You can add multiple Tacho bridge applications installed on different computers to the tab. It will allow different employees who use this account to request tachograph files from their computers.
Adding companies to the module includes:
- Adding company cards to the Tacho bridge application
- Adding companies to Wialon Platform Studio
To add company cards to the Tacho Bridge application:
- Open the Tacho bridge application.
- Insert the company card into the card reader connected to your computer.
- When the application detects the card, click the icon
in the card section.
- Take out the card and find the company card number printed on it.
- Specify the company card number in the application.
- Insert the card into the card reader.
- Click Save.
To add companies to Wialon Platform Studio:
Navigate to the Companies tab.
If you haven’t created any companies yet, click Add first company on the empty page.
Click Add company.
Enter the company name.
Specify the company card number.
Click Save.
After that, the added company is displayed in the list of companies.
You can link only the devices that support tachograph functionality. See their list on the Tachograph control page.
To link devices to the added company:
- Navigate to the Companies tab.
- Click on the row of the company to which you would like to link a device.
- Go to the Devices tab of the company details.
- Click Link devices.
- Select the devices you want to link to this company.
- Click Add.
- Click Save.
The devices are now linked to the company.
You can also link a device to a company in the device details when configuring the tachograph functionality for a device.
