Viewing the audit log
Where: Wialon Platform Studio
The audit log is a dedicated page in Wialon Platform Studio where you can view all operations performed on items in your and your customers’ accounts. This audit log includes information from the individual audit logs of customers, devices, map services, as well as provides data on other items such as notifications, geofences, sites, and so on.
To open the audit log, expand the Access and logs section in the navigation menu and select Audit log.
By default, the audit log shows data for the last 7 days. You can request an audit log for a different period. To do this, set the necessary period using the date picker and click Apply.
The audit log is displayed as a table with the following columns:
Column Description
Time The time when the operation was performed.
Executor Indicates whether the operation was performed by a user, automation, token, or support specialist.
Email The executor’s email address, if available.
Item type The type of item that was created, updated, or deleted.
Operation Indicates whether the item was created, updated, or deleted.
Details Details of the operation, if any.
IP address The IP address from which the operation was performed.
To download the audit log in CSV format, click the CSV button.
To filter the table, click the search field and use the necessary filter. The following filters are available: executor, executor’s email, item type, item name, operation, additional details.
You can manage the audit log table in the same way as the table of devices.
