Generating “Driver behavior violations” report
Who can do it: Customer
Prerequisites
Wialon Platform FleetSpace allows you to generate reports on driver behavior violations. To do this:
  1. In Wialon Platform FleetSpace, navigate to the Reports page.
  2. In the dropdown list, select the Driver behavior violations report type. The settings selected for this report will be saved for this session.
  3. Set the time period using the calendar.
  4. In the Grouped by field, select Drivers or Devices.
  5. Select the specific devices you want to see in the report.
Once you select a device, the report will be generated. You can navigate to other pages and return to your report. The generated report is available for 1 minute.
The resulting report layout is organized into two main sections: a summary at the top and a detailed breakdown below.
Service providers can configure automatic report sending by attaching it to the automations with the actions Send an email and Send Telegram message.
Driver behavior violations summary contents
The top section of the report provides a high-level summary of the data. It includes the following information:
  • Number of violations: The total number of all recorded driver violations.
  • Number of vehicles: The total number of vehicles involved in the violations.
  • Total mileage: The combined distance driven during the trips that included violations.
  • Total trips duration: The total time duration of the trips that included violations.
Driver behavior violations detailed information
The lower section of the report provides a more granular view of each violation, organized by vehicle. The columns in this table present specific information about each infraction:
  • Device: Identifies the specific vehicle associated with the violation.
  • Criteria: Describes the type of violation that occurred.
  • Driver: Identifies the driver assigned to the device at the moment of violation.
  • Max. value: The maximum value recorded for the specific violation criterion. This indicates the severity of the violation.
  • Time: The specific time the violation occurred.
  • Location: The geographical location where the violation took place.
  • Duration: The length of time the violation lasted.
  • Mileage: The distance covered during the trip that included the violation.
Exporting the report
To download the report, click the icon icon with downward-pointing arrow above a horizontal line in the top right corner of the screen. The report will be downloaded in .CSV format.
Driver behavior violations on the map
To display violations on the map, use the Track player.
