Analyzing driver information in reports
Who can do it: Customer
Wialon Platform allows for detailed analysis of fleet operations by integrating driver information into various reports, including Trips, Parking, and Idling reports. This enables fleet managers to understand driver performance, adherence to schedules, and impact on operational efficiency.
You can use drivers using the driver-related features in reports described below.
Grouping reports by drivers
This allows you to analyze data such as mileage, duration, and events, broken down by individual drivers. The grouping type is available in the following reports:
- Trip
- Parking
- Connection loss
- Tasks
- Forms
- Driver behavior violations
- Private mode
To group the data by driver in reports:
- In Wialon Platform FleetSpace, navigate to the Reports page.
- On the left top of the screen, in the Grouped by field, select Drivers. The settings selected for this report will be saved for this session.
- Click the Drivers field on the right to open the dropdown menu.
- Check the boxes next to the names of the drivers you want to include in the report.
The information in the generated report is grouped by drivers. Click the icon
to expand the row and see the details. You can navigate to other pages and return to your report. The generated report is available for 1 minute.
Analyzing the “Driver” column in reports
The Driver column is available in the following reports:
- Trip: The column displays the name of the driver that was assigned to the device during the trip.
- Parking: The column displays the name of the driver that was assigned to the device during the parking interval.
- Idling: The column displays the name of the driver that was assigned to the device during the idling interval.
- Connection loss: The column displays the name of the driver that was assigned to the device during the connection loss interval.
- Tasks: The column displays the name of the driver assigned to the task.
- Driver behavior violations: The column displays the name of the driver that was assigned to the device during the violation interval.
- Private mode: The column displays the name of the driver who was assigned to the device during the private mode interval.
The Forms report contains the driver name in the Form submissions column if this driver submitted the form.
