Managing the driver table
Who can do it: Service provider, Customer
In Wialon Platform FleetSpace, the created drivers are displayed in the driver table. You can manage it using the following actions:
  • Sorting the table contents
  • Adjusting the column width
  • Hiding and showing the columns
  • Reordering the columns
You can sort the drivers by name, phone number, driver code, and assigned device. To do so, click on the necessary column header. For a descending sorting order, click on the header again.
To adjust the column width, hover over the column header, click on its border, then drag and drop it as needed.
To hide the columns you don’t need, click the icon gear icon, and cancel the column selection. To show the column again, select it in the same menu.
To restore the table settings to default, click Reset.
To change the order of the table columns:
  1. Click the icon gear icon.
  2. Click the icon opposite the name of the column you want to move.
  3. Drag and drop the column in the necessary order.
