Managing a driver profile
Who can do it: Customer
Managing driver profiles involves adding new drivers, searching for drivers in the list, granting them access to Wialon Driver mobile application, and associating their tachograph card codes for compliance and data collection.
Adding a new driver
To add a new driver profile, follow these steps:
  1. Log in to Wialon Platform FleetSpace.
  2. Navigate to the Driver management page.
  3. Click the New driver button.
  4. In the driver profile form, enter the following mandatory information:
    • Name: The driver’s full name.
  5. Optionally, provide additional details:
    • Photo: Download the driver’s photo. The maximum file size is 12 MB.
    • Code: The driver identification code. The field accepts small and capital letters and numbers. You can use this field to enter the driver’s tachograph card, employee ID, RFID tag code, or iButton value depending on the purpose.
    • Phone: The driver’s contact phone number.
    • Additional properties: Any additional information defined by the service provider (for example, Driver license number, Emergency contact). See how to configure the additional properties in the Setting up drivers quick start guide.
  6. Click Save to create the new driver profile.
A new driver profile is now available in your account.
Automatic creation of drivers
The system can automatically create drivers from tachograph files and driver card telemetry.
From tachograph files
When a tachograph file is uploaded from a device, the system checks its metadata for a driver identifier. If no existing driver has a matching driver code, a new driver is created automatically with the following poperties:
Property Value
Name First and last name extracted from the tachograph file metadata, followed by (autocreated). If the names are empty or missing, the driver is created as Unknown Driver (autocreated).
Driver code The driver identifier from the tachograph file metadata.
App access Disabled. The driver can’t log in to the Wialon Driver app until access is explicitly granted.
From driver card telemetry
When a driver card is inserted into a device and the reported driver code doesn’t match any existing driver, the system creates a new driver automatically and assigns them to the device. The driver is created with the following properties:
Property Value
Name Unknown Driver. Unlike tachograph files, sensor telemetry doesn’t include the driver’s name.
Driver code The driver identification code reported by the device sensor.
After drivers are created automatically, they appear in the driver list and you can manage them like any manually created driver: update their name, assign a phone number, grant app access, or assign them to a device.
You can search and filter for drivers on both the Driver management and Drivers online pages to quickly find the information you need.
The available filter criteria depend on the page you are on.
On the Driver management page, you can filter by:
  • Driver name
  • Phone number
  • Driver code
  • Device: The vehicle a driver is assigned to. You can select one or more devices or choose the Unassigned option to find all drivers who are not currently assigned to any vehicle.
On the Drivers online page, you can filter by Driver name and Phone number to quickly locate a driver on the map.
To find a driver, use one of the following methods:
Method 1: Quick search
This method is best when you know the device, name, or phone number of the driver you are looking for.
  1. Navigate to the Driver management or Drivers online page.
  2. Start typing in the search field. As you type, the system will suggest matching criteria.
  3. Select a criterion from the list.
The list is filtered to show all results that match your selection.
Method 2: Filtered search
In this method, you start searching by filtering the list first.
  2. Click on the search field to open the filter options.
  3. Select a filtering criterion. Note that the Device filter is only available on the Driver management page.
  4. Select one or more specific values. For the Device filter, you can select the Unassigned option to find all drivers who are not currently assigned to any vehicle.
  5. Click Apply to see all the results matching the selected filter.
  6. To add another filter, click on the search field again and select an additional criterion.
Enabling access to Wialon Driver app
You can grant drivers access to Wialon Driver mobile application, allowing them to view their information, trips, and manage forms.
To enable access to Wialon Driver app:
  3. Click on the driver’s name to open their Profile.
  4. Locate the Access to driver app toggle switch.
  5. Toggle the switch to on to grant access.
  6. Once enabled, an Access password field will appear:
    • Enter a password for the driver following the requirements or generate a secure password using the icon .
    • Use the icon .to view and check the password.
  7. Click the Copy credentials button to easily share the login details (phone number, password and realm) with the driver.
  8. Click Save to apply the changes.
The driver now has the credentials needed to log in to the Wialon Driver mobile app.
Allowing drivers to manage private mode in Wialon Driver
You can allow drivers to manage private use in Wialon Driver. To do this:
  1. Enable access to Wialon Driver in the driver profile: follow the steps 1-5 from the Enabling access to Wialon Driver app instruction.
  2. Enable the option Allow driver to control private mode.
  3. Save the changes.
The driver can now enable, prolong and disable private mode in the mobile application. See the guide for drivers on the page Managing private mode in the Wialon Driver documentation section.
Revoking access to Wialon Driver app
You can revoke access to Wialon Driver app for all the drivers of the customer. To do this:
  1. In Wialon Platform Studio, navigate to the Customers page.
  2. Select the specific customer.
  3. Click on the Settings tab.
  4. Expand the Access to Wialon Driver app section.
  5. Click Revoke access.
  6. Click Apply to confirm the action.
  7. Save the changes on the page.
Now the drivers of the customer don’t have access to the app. To restore the access, enable it on the Drivers: management section following the guide.
