Playing tracks
Who can do it: Customer
After retrieving tracks, you can play all of them simultaneously, or select a specific vehicle to play its track separately.
Playing all tracks simultaneously
To play all the tracks simultaneously, follow the steps below.
  1. At the bottom of the track list, select the playback speed using the slider or by clicking on the playback speed value. The available values are 1x, 2x, 5x, 10x, 20x, 30x, 50x, 100x, 200x, 500x.
  2. Click the icon .
You can view the tracks being played on the map and in the track list. If the list is too long and covers the map, you can collapse it by clicking the icon . Use the icon to expand the list again when needed.
To zoom in and center the map on a specific track, hover over the vehicle name and click the icon .
To remove the track of a certain vehicle from the list and map, hover over the vehicle name and click the icon . This action doesn’t delete the track from the vehicle history.
Playing a track separately
To play the track of a specific vehicle separately, follow the steps below.
  1. Click on the name of the necessary vehicle to open its track details.
  2. Select the playback speed using the slider or by clicking on the playback speed value. The available values are 1x, 2x, 5x, 10x, 20x, 30x, 50x, 100x, 200x, 500x.
  3. Click the icon .
You can view the track being played on the map and in the track details. You can collapse the tab by clicking the icon . Use the icon to expand it again when needed. To return to the track list, click the icon .
Pausing, fast-forwarding and rewinding the track playback
To pause the track playback, click the icon .
To fast-forward or rewind the track playback, you can use the following features:
Feature Description
/ Use these icons to fast-forward or rewind the track playback by the number of seconds corresponding to the playback speed value. For instance, if the playback speed is 100x, the icon fast-forwards the playback by 100 seconds.
/ These icons are available only when playing a track separately. Use them to fast-forward () the track to the next trip, or rewind () it to the previous trip.
Lines above the timeline Hover over the lines above the timeline and click the point from which you want to start playback. The gray tooltip shows the date and time the vehicle passed through each point.
Track points on the map To fast-forward or rewind the track playback on the map, hover over the track line and click the point from which you want to start playback. The tooltip for each point displays the date and time the vehicle passed through it.
While playing the track, you can view and analyze its data. For further information, see the Viewing track data page.
